I felt I was a little mislead when I read that Wyze cam’s work with the Google assistant. I was hoping I could integrate into my routines (ex. Turn the camera on when I say ‘ok google’ turn on ‘Waze camera A’). In the Google routines there is an option to use a security system, but Google doesn’t see Wyze as a security system. So I have to turn the camera on or off manually through the Wyze app each time I wish to, separately from all my other devices that connect through Google. It’s a minor inconvenience, but if that can be fixed, I’d appreciate it.
Mod Note: Though the original post here refers only to Google not seeing Wyze as a security system, the topic is now generalized to include all missing functionality for Google control and status of Wyze devices.
I think the main reason Google does not see WYZE as a security system is because it is not marketed as one as WYZE says not to use it as one. Although I know people do, including me.
My guess is for the most part yes, but they claim they will restore some things with a Google API after killing the Nest API. It’s mainly a wait and see what happens, the supposed date they will kill Nest API is Aug 31
The specific issue is that Nest’s integrations with IFTTT (specifically the Nest Thermostat, Nest Protect, and Nest Cam services) are going away. I am not aware of any plans to end Google Assistant’s ability to work with IFTTT.
This part of the topic can already be accomplished using the Shortcuts feature of the app. To learn how to use Shortcuts, click the Support link, top right.
Having integration with Google Assistant is what he/she is asking for. Being able to trigger a scene even with IFTTT would be amazing. Or asking Google to trigger a scene would be game changing. Shortcuts inside the app isn’t really a shortcut. Triggering with an assistant is a shortcut.
I just got my wyze sensors and would love it if it were possible to set a routine/action that if I open my front door it checks other sensors to make sure they are closed and sends a notification confirming that.
Also Google Assistant integration would be great so when using Google routine it can check the status
I specifically bought these because of the announcement for Google assistant. Its infuriating to see this stuff continue on in tech after working in the biz for 20 years. I cant turn off the camera but can turn it on? Thats like saying I can turn on the light bulb with a routine but nope not off.
Current Google Home integration is a true disappointment. Live casting is limited to only 10-minute but that wouldn’t be that big an issue if it actually worked. Too buggy sometimes getting a blank screen with the time limit winding down and it may or may not come up a few minutes later but then times out.
I have the same issue. Google Assistant can turn the cameras on, either with my “I’m Leaving” routine or when I just ask it to. It cannot turn them off either way. It’s weird.
