Getting RTSP url
Is there a way to get the Rtsp url after flashing? The advanced settings in Wyze app doesn’t have that feature anymore.
Thanks
Yes it does. At the very bottom of the Advanced Settings page is the setting to turn RTSP on or off. Select that and if turned on, the link will be shown.
Here you go:
Did you flash non-RTSP firmware to the camera???
Thanks, yes it does if RTSP firmware is properly loaded. Otherwise doesn’t show, in which Wildbill caught and questioned.
I thought my Rtsp firmware flashed, but it hadn’t.
Thanks for responding.
Good catch, it hadn’t flashed. All good now!
Thanks
