Garage Door camera will not connect
My garage door camera disconnect from my network and will not connect. I have followed all the trouble shooting suggwstions and nothing works, i.e. reset, disconnecting for power, ets.
Help!!
If its just the camera, grab another V3 and wire it up in place of the camera to get back in service.
Then you test the removed V3 for issues. IF you recover it, put it up some place else.
I had a recalcitrant V3 which would no longer run the lamp socket, or recognize the SD card..
Moved inside to a spot where I don’t care about any of that, and don’t want recordings anyway.. So good to go..
