I have an outside camera that I can’t figure out how to set “Waypoints” plus it doesn’t follow activity/action.
are you using the Pan Cam v3? or the Outdoor cam v2 as indicated in the tag?
Asking because the WCO V2 or V1 does not Pan or move. So no Waypoints. If you want a camera which follows motion, pans to waypoints, you will need to use the Pan Cam V3. Do you need a battery Camera?
Note: I have removed my WCO v2 sometime back in favor of the Battery Cam Pro (BCP). However, it should be noted that the BCP does not Pan either.
Using the Pan Cam v3 .
