I have had the Floodlight V2 for a while. Its great. I originally removed the switch on the circuit it was and so it would have constant power. Then I came accross the Wyze switch. Figured id be able to use the switch to turn the light in the floodlight on and off. It seems like I can but not with just a single press. Single press will either turn the entire floodlight off or on. Not the just the light. Is this possible?
Welcome back to the forum @marc.b.tremblay!
Unfortunately no, you cannot use single press with the Wyze switch to turn the Flood light on and off.
As you have determined that will cut power to the device.
The only alternative is to use the Additional Actions on the switch. Double Press, Triple Press, and Press and hold to control the Flood light.
