Floodlight Specs
Does anyone know the specs for the center screw that mounts the floodlight? Very nice detail about the various mounting screws. However the center screw that attaches the floodlight to the hanging bracket is just labeled “Floodlight Screw”. Not very helpful when you need to replace one. (And I stupidly dropped mine and can’t find it), Hopeful that Home Depot has a replacement (if I knew what I was looking for). Help appreciated.
UPDATE
Thanks to Customer, I was able to find the screw at HD. It is indeed a 1" long #10-32 machine screw. Many thanks.
Here you go!
Does anyone know if the floodlight pro uses the same screw thread? I know for a fact it is longer than the screw provided with the regular V1 floodlight.
