Floodlight pro
Is there a way to limit notifications on floodlight pro to only people or vehicles? I get a lot of notifications even when a bug flies by.
Welcome to the forum @lds73!
Yes, this capability is possible. However, it does require a Cam Plus License to be able to manage those options.
If you do have Cam Plus, you can go into the Flood Light Pro Settings, Event Recording, then select Smart Detection and go to the Smart Detection Settings, Select the objects (Person and Vehicle) you would like the device to be able to detect.
Go to Notifications and Select the Motion Events you would like to have notifications for.
You should then only get notifications for the detection items you have selected.
If you need any additional assistance, let us know.
