Floodlight fade on/off
It would be great to add a feature to the floodlight pro where, when motion is sensed or the “turn lights on” rule is triggered the lights could fade on vs immediately being turned on. I would this this would be an option when selecting the action, something like: turn lights on, sub option: fade?
Same could go for turning the lights off.
This could go for the floodlight as well, I just don’t have one of those so not sure if it does or doesn’t already do this.
Why? This is a much more user friendly way of turning the lights on when you’re using it for convenience vs try to startle a would-be bad actor.
Welcome to the Wyze User Community Forum @paulerskine! :man_raising_hand:
If you would like to request that Wyze add this feature, that is handled thru a new topic post in the Wishlist. Go to the Wishlist, search the topics for one that matches your request. If you find one, vote for it at the top, like :heart: some posts, and add your reply post to support the request. If you do not find a match, submit a new topic for approval.
Interestingly, Alexa Routines have this Ramp Brightness capability in the Actions for the FLP although the only triggers are On\Off and Person Detection (CP Required).
Wyze Rules do not have this capability
