Floodlight Cam v2 disconnecting daily, also unresponsive to restart
I recently installed two Floodlight Cams v2 and are working well, with the exception that they both disconnect almost every day. Power cycle fixes one of them, but i cannot power cycle the other. This one i cannot power cycle is stuck with the floodlights on and does not respond to the factory reset (holding setup button).
Any reason these keep disconnecting? The wifi signal is good, no issues with power.
When you state the FL cam won’t respond to factory reset, are you firmly holding the setup button down for a full 10 second count until the status light turns solid red and you hear the ding ding sound?
