Floodlight always on with RTSP enabled
I have a floodlight that is using the old RTSP firmware but it is causing the floodlight to remain on all the time once dusk hits. Any ideas how to make this work properly?
You probably need to flash standard firmware. The RTSP is too old and doesn’t support the floodlight.
I agree with WildBill, the RTSP firmware wasn’t designed to support the floodlight. If you need RTSP on that camera, I would switch back to the main firmware and then just use Docker Wyze Bridge to get the RTSP stream. Then you’ll have the best of both worlds.
