Fix-It-Friday 7/1/2022
After update, I can’t seem to have audio of 2 cameras at once?
I set up a camera group and use as a baby monitor for my twins.
If this was causing issues, can you add an alternating mode that switches every few seconds?
Welcome to the Wyze community dlcomer1982. The Wyze app has never supported playing simultaneous audio streams from multiple cameras. Please vote for these 2 wishlist requests:
Playing Sound for Multiple Cameras in Group
Baby Mode - Alternating Audio in Groups
And guys, this Fix-it Friday is closed. They gather up the issues posted a few days after the Friday in question. The next Fix-it First-Friday is in 2 weeks on Aug 5th. So for best visibility, post any new issues when that thread appears! :slight_smile:
The most recent app update fixed this issue! Thank you!
The Google home issue
Hi, everybody! :grinning:
It’s time for the Fix-It Friday follow-up! Keep in mind that we’ll have a new callout for bugs next week so please keep an eye on your experience in case there’s something impacting you! Let’s check out our current list:
Reddit - Touch target for back buttons on iOS isn’t placed correctly :point_up_2:
This report was actually a feature request! We’ve sent it to the appropriate folks but won’t be reporting on it in Fix-It Friday updates later.
Discord - Wyze Air Purifier goes offline often
1.0.9 is still in beta testing! If you’re a beta tester, please give it a try and let us know how the connectivity treats you.
Let’s Take a Look at Some Previous Submissions
Wyze Air Purifier Insights graph is not updating when expected :chart_with_upwards_trend:
We’re still in the design phase for this. For those less familiar with this entry, here’s what we’re working on:
We have started development for the firmware changes related to the reporting mechanism. Our Design team is working on the new UI. This is a bit tricky because we need two different UI designs so we can support people on the new firmware and those that haven’t updated from the current firmware yet when the time comes. We don’t expect to have the update for this out in July but we’re hoping for August if everything comes together smoothly.
Wyze Cams on Cam Plus are only receiving Wyze AI notifications and not the standard motion-only notifications
If you’ve been running into this, could you please let us know if it’s a current issue for you? We found a bug on the cloud side and resolved it but we don’t want to ignore a possible secondary issue causing similar symptoms. If you are experiencing this, please submit a log in the following way:
Account > Wyze Support > Submit a log. Select your affected device from the dropdown menu so we have a device log. Fill in the description field with a description of what’s going on and the date, time, and time zone for affected Events. Make sure that the send log option is selected and then submit it! When you have the log number, please post it here so we can escalate it for you with your report.
Wyze Video Doorbell is getting stuck on 3/3 instead of displaying the live stream :three:
We don’t have a further update on this one so here’s the update from before:
The beta for this has been postponed. We paused the current public firmware as we look into some issue reports from our reviews. The beta requires that update to be applied first so we want to be careful with how we release this.
Wyze Headphones no longer use auto-pause but the headphones go into Transparency Mode still when laying down :headphones:
We’re waiting to hear back from the manufacturer about this one so we don’t have an update this week. Thanks for your patience!
Audio out of sync on saved videos
No further update on this one. We’ll release it when it’s ready after beta testing!
Cameras appear offline in the app, though they are online and viewable
We saw a report of this in beta so we’re doing some digging. Hopefully we’ll be able to release the firmware to the public soon.
Attempting to view microSD card Playback when viewing an Event from a Wyze notification results in the, “No microSD card installed in camera” error :floppy_disk:
We released the 2.33 app to the public last week! The rest of the improvements for this issue are in there. Please let us know if you continue to run into this problem. If it seems to be resolved, we’ll take this entry off the list for future updates.
And there you have it! See you next week for Fix-It Friday. Have a great week!
Thanks Jason!
Hello, everyone! :smiley:
Welcome to this week’s Fix-It Friday follow-up! We’ll have another callout for bugs to add to the list so make sure you document any that you run into! Here’s what we have still on the list for this week:
1.0.9 is still in beta testing but is expected to release this week! If you’re a beta tester, please give it a try and let us know how the connectivity treats you.
If this is an active issue for you, we need your help to solve it! We adjusted some things on our end and that seems to have helped some folks. If we don’t get engagement with this one after this week, we’ll be removing it from the update list. If you are experiencing this, please submit a log in the following way:
We just started the beta for this improvement! We suspect this isn’t fully resolved with this beta build so we also added some logs to collect related information if people continue to run into this. Beta testers, please give Wyze Video Doorbell firmware 4.25.1.090 a try and let us know how it goes!
We’re still discussing this one with the manufacturer so we don’t have an update this week. Thanks for your patience!
No further update on this one. We’ll release it when it’s ready after beta testing! We haven’t been able to reproduce this problem on our side and haven’t heard negative beta feedback about it yet.
We checked the logs from the recent report and found them to be related to an AWS issue from 7/16. So far things look promising! We have new beta firmware for testing coming soon.
We have a bug fix in the 2.34 app about to enter beta testing. Currently, the Playback button is grayed out in the Events tab without a license attached to the camera. We’re super sorry about that and are working to fix it quickly! Once that is resolved, we’ll remove this entry from the update list.
That’s a wrap! See you on Friday for the Fix-It Friday bug callout!
Closing out this month’s Fix-It Friday. New updates can be found in next Month’s thread found below.
