First event of the day not playing
Have a V4 cam. When I view Recent Events all seem to play with the exception of the very first event of the day. First one seems to get hung up on “loading event”.
Since nobody has responded to your post I will tell you that it has been posted previously and I will try to find a link to the post. I have three V4 cams and have had that same issue twice in the last few months, not every day. If it happens when I go to the events page of the app I will the open the live view of the cam and tap the “Recent Events” shown on the bottom part of the screen tap the event and it usually plays. If all else fails play it pack from the SD card then try events again. If you don’t have an SD card in the cam shame on you. I have 256GB cards in all my V4 cams set for continuous recording.
I have those today, and not on a V4 and not just the 1st event. I see similar complaints on the net. It seems the Wyze servers are more troublesome than normal.
I have seen it on my single v4 only once and I don’t have an explanation except to chug it to Wyze/AWS glitch. Don’t forget that event videos are server dependent.
Which is why MFP, possums, :skunk: and the :raccoon: gang like SD cards to capture their adventures.
I hear you brother, loud and clear :laughing:
Thank you. Yes, I have an SD card recording 24/7
Anyone else notice when viewing SD card Playback does your timeline jump from 23:59:59 to 00:01:00?
I can hit the Backward button and view the skipped minute but it is just weird.
Cam v3 on firmware 4.36.13.0416.
If I remember correctly this was discussed before. I haven’t noticed on mine as I don’t pay too much attention.
The bug has been around for awhile. It doesn’t bother me too much as I only check the first minute of the day on New Years.
Wyze developers can’t add base-60 numbers it seems. Not too long ago, they rejected time periods from say 10pm to 1am.
So, you only have a problem once a year :wink:
No, Playback skips the first minute of everyday for me at 23:59:59.
I really only view the first minute on New Years Day.
I actually forgot to lift the first minute of 2025 from my SD card. Here is the first minute of 2024 at my house.
I’m having the same problem with the Outdoor Cam V1. I have had for years with solar panel and has worked perfect until a couple of months ago when the same thing is happening. First video of the day doesn’t load. Has to be a problem with an update obviously.
Has anyone on this thread had a status change or remedy since the last post on Feb 4?
There has been no change for me. I’m hoping Wyze is still looking for a fix.
