CamPan3 was 4.50.17.10, did the update to 4.50.17.19.
Camera would not start up . Had to go out to power cycle. ![]()
Auto update getting re-enabled happened to me, as I’ve been purposely on an old firmware that just worked without any of the issues people complained about with newer firmwares. Now I’m stuck with new firmwares with bugs, and had to manually go through each of my cameras one by one to disable auto update again (which may be a moot point as I now need to try new firmware versions and pray it fixes the problems).
I asked about it and was told there were no forced firmware updates or re-enabling of Auto Update, but it’s been reported by multiple people in these forums.
guess I’ll have to hook up my cams and see if it fixed anything .lol
only cam that works is the DUO door cam .. better not screw that one up
@WyzeJasonJ There is a problem with the v4 firmware or maybe it is the latest Android App. Either way, all of my captured v4 events stutter during playback. The same thing happens when watching v4 video from an SD card.
However, if you download the event, the downloaded video plays just fine. On the other hand, if you record from the SD, the video contains the stutter.
v4 firmware: v4.52.17.19
Android App: v3.22.0 (973)
Downloaded Event from App:
Recorded video from SD:
My v4s still don’t have the update offered to them again after the last updates failed…
@WyzeJasonJ do you have any insider info from Suze regarding this update?
Why was it pulled and it’s there an update in the works?
There appears to now be a newer version of the C4 firmware (4.52.17.26) which is not mentioned on the release notes page ..
For me this had the same behaviour as the previous firmware they pulled.
I start the upgrade and it sits there for an hour saying updating but eventually does nothing.
@WyzeJasonJ What’s going on with the V4 updates?
Gabbo
I checked yesterday and 2 of my V4 cameras had already updated to the latest firmware. The other 2 game me a manual update option. I did them one by one, this FW takes a long time to install but it does go thru eventually.
All my V4 are now showing the latest version installed. Will monitor them in the coming days in case there are issues. What a ride this has been!
I managed to update my v4s to the latest version.
The problem seems to be on the multiple firmware update page, I couldn’t do it from here.
It would say updating and do nothing.
What was successful for me was going into individual camera view->settings->info and launching the firmware update manually from there.
The update completed in a couple of minutes.
Then do the same for the next one.
Gabbo
Yes indeed. People have been reporting this issue for most if not all of the year. Add it to the list of known issues.
