Firestick on TV - Remove dark frames?
Hi all.
Quick question. I started using my Wyze 2 on my TV through Alexa/Firestick. Love that feature. On thing that is really annoying though are the dark fading overlays on top and bottom of the image. I’m assuming it is to help show the name of the camera on top and the date/time on the bottom. Is there any way to get rid of these frames? I find them annoying and it makes it hard to see the image through them. If this is not possible, I really hope that could be made an option.
Thanks!
Hm, I’m not getting that. I just have the camera name in white lettering up in the top left corner.
Strange, but thank you.
I’m having the same issue. This is the only similar post I found- anyone find a resolution?
I’m the OP. Never got any real replies, nor has it changed in the last 5 years. Doubt it ever will.
It will never change as this is an Amazon not Wyze issue. The app is officially supported on iOS and Android only.
