Feb firmware updates, now wyze is a hot mess
All cams, v2s, v3s, v4s… all take FOREVER to load.
The changes in the app are bad, but this slowness has me about to toss all this wyze stuff if a fix doesnt get pushed SOON.
I’ll take less ‘security’ to get back to where the cameras popped up and were ready in the blink of an eye.
Try clearing the cache from within the app. This is done by going to account, app settings, clear cache.
Then shut the app down by swiping up.
Since you are on Android, long press the app and select app info. Once there go to storage and cache and clear cache there as well (not Storage), then do a force stop and close the info window.
Restart the phone and try again.
This helped me….. thanks for posting.
I’d done that before, was no help, but today, after doing that, things have improved considerably.
Still not the snappy response that we had before, though.
Thanks
Any time I clear the cache within the Wyze app, I also go into the OS storage settings for the wyze app (android in my case) and clear the cache there too. Not data, just cache. I don’t do it frequently but if I’m seeing odd things it makes sense to do both.
In the past (year or more) there were some app updates that I actually had to uninstall and reinstall the app to get things working again, but that was more around the time that they upgraded from the 2.x app to the 3.x one and due to being a major upgrade, a clean install seemed to work better. I haven’t had to do that in a long time.
