Sadly, not all of us can wear a normal length wristband or watchband. I would love to buy a couple of Wyze Bands, but the straps are too short. An extra inch or inch and a half would be enough to cover most people. You wouldn’t even need to create a separate set of Bands, just sell the longer straps as a replacement part.
Maybe I have a bigger wrist than I realize but I’m at the second-to-last hole on the strap that ships with the watch, and the included strap with buckle seems to be the same length. I would have expected at least a few extra holes of slack in the standard size band. At the moment it isn’t a problem for me but I could see it not fitting some people at all. Maybe when there are different length bands people could choose at time of order which they will need?
Wondering if you might create a larger band for the Wyze Band. The current band barely fits my wrist and is on its last hole and i am not sure the band will hold up to the wear and tear of everyday use with it being on the last hole.
Agreed. The only reason I haven’t bought any of these is I need a bigger wrist strap option or upgrade even.
Same here, have a larger than average wrist and the band is about an inch too small, would buy one otherwise.
I have not currently purchased this product. I myself, am in the same boat. I have a very large wrist, thus am unable to wear most watches of any kind. A standard watch band just does not fit my wrist; even to the last hole. My wrist is nine (9) inches around and you just don’t find watch bands of that size. Even the bands that say they are 9 inches are usually tight at the last hole, leaving an imprint of the watch band when I take them off.
