Expired subscription no longer records locally
I found that the ONE camera that was NOT a part of this 30 day trial records locally and displays in the Event tab. How can I get the others to do the same, they way it used to be? I selected Cam Plus Lite in an attempt to show in the Events tab without luck, and the SD cards do not record AFTER the trial.
If you have cam plus lite, you should be able to add the cams to that and have your 12 second clips back, plus SD card recording. May have to do a “reset services” after adding them.
If you don’t want them on cam plus lite, I’d try my suggestion to delete and reset the cams, then re-add them back.
Make sure your SD card is recognized and you have SD card/events recording enabled. It should record to the SD card no matter what, even a brand new camera that is unconfigured will record to the SD card as soon as you insert it.
But I’m wondering if you’re confusing the ways to play back cloud recordings (cam plus lite / cam plus) with the way to play back SD card recordings, since they’re totally different?
My cam v4 stopped working after the camplys trial ended.
I go to settings → event recording → recording type and only shows option for *thumbnail" and “video” that requires a camplus subscription. SD card only captures thumbnails.
[MOD Edit]: Please ensure posts follow the community guidelines
Are you seeing the thumbnails in the event tab?
Asking because Cam Plus is not required for SD Card. Are you setup for Continuous recording or event only?
Now that your trial has expired, you may want to try resetting your event recordings to be All Motion and ensure that no smart events has been selected.
Is it possible you’re just getting confused (understandable, they make it confusing) about how to access subscription videos vs SD card videos? See image below
If that isn’t it, try doing a “reset service” in the camera settings. Perhaps even delete it from the app (which should factory reset it) then re-add it. If you use the same name, it should download most of your old settings (just not hopefully the cam plus subscription).
