Event recordings disappear
The camera seems to be working great. I have recorded event notifications. I click on one and all the rest disappear. I can watch the one I clicked on but when I go to the event log, they are all gone. Not sure what to do.
Thank you✌
Welcome to the forums!
Remove all filters in the event tab. I bet there is a filter enabled that is excluding some events. In the event tab, click on the filter funnel looking this in the upper right, then clear app and apply. We can start there. :slight_smile:
Thank you, that solved it, there were several filters on. I must have checked them when I set it up, I’m still learning.
Thanks again✌
