We have 6 cameras and 2 of them are set up with event monitoring but the one over the driveway will just stop recording events. The front door one continues to work well. I have to go into the cam setting and click detect motion after a day or two as it turn off. V2 regular cams. Any ideas?
Do you have a shortcut setup to turn it off?
Doh! Our IFTTT applet is turning it off but not back on for some reason. I’ll just disable it and see if it works. Thanks
No problem. I’m glad you found it.
