Event Recording Choices
It would be nice if the Wyze app would allow one to set the camera to only record events and notify on weekdays. It basically needs a more granular choice of when to record and notify that there was movement. (e.g. “Weekdays”, “Weekends” or just have the ability to check off days of the week you want it to record. )
This can can currently be accomplished by using the Shortcuts feature of the app:
https://support.wyzecam.com/hc/en-us/search/click?data=BAh7CjoHaWRsKwjT%2FZrSUwA6CXR5cGVJIgxhcnRpY2xlBjoGRVQ6CHVybEkiLi9oYy9lbi11cy9hcnRpY2xlcy8zNjAwMTU2NTg0NTEtU2hvcnRjdXRzBjsHVDoOc2VhcmNoX2lkSSIpNDgxMDFhNWYtZjU3Ni00MmYxLTk1YTMtZDMwODVjZjVmNzE1BjsHRjoJcmFua2kG--27c5b461f6b0e92efcc06dcc91cdf3712fcc6015
