Running android 17 beta, when selecting the door lock, getting an error code of java.security.cert.CertPathValidatorException: Trust anchor for certification path not found..
Works perfectly on iPhone and Android 16 but having an issue with the new Android 17 beta..
Which Android Wyze app version are you using on the Android 17 phone? Is this a new issue? I imagine that you’re probably using the same Wyze app version on both Android 16 and Android 17 beta, but it’d be good to confirm that. I’d also probably log it and then contact Wyze Support with the Log ID and, additionally, possibly post a report and the Log ID to whichever Wyze News or Beta topic is appropriate to your app version. If you’re using the same Wyze app version on devices running two different Android versions and experiencing a difference between them, though, then I’d be inclined to think that this is something Google will have to fix.
My other thought as a non-developer is wondering if this is another downstream consequence of certificate issues that have been reported, such as in this recent topic:
Is it working for you now on Android 17 (if you’ve updated to it)? I was having the same issue running Android 17 QPR2 beta (but from what I understand, the issues was for Android 17 as a whole). Yesterday I noticed that the app is working again. I’m guessing they must have updated the certificate.
