Electric Heat Pump and Propane 2-stage Furnace - Wyze Thermostat?
Hi,
I’m looking to get the Wyze Thermostat and have searched the compatibility and here, but can’t find my exact situation.
I have an Electric Air-Source Heat Pump and 2-stage Propane furnace. I currently (when it’s not to cold) run the heating on the Propane Furnace during the day (when Electricity is expensive) and the Heat Pump in off-peak electricity hours. With the current thermostat, the Heat Pump is ‘Heat’ and the furnace is ‘Emergency Heat’ (if the temp does not come up/is not maintained, the furnace kicks in automatically).
The current Thermostat Wiring has the following connected :
LED2 (for when EM (furnace) is on)
RS2
RS1
RS+V
W1
Y1
G
R
(R and 24V bridged)
24V(C)
O
The compatibility checker does not give these options for wiring, so my question is 'Is the Wyze Thermostat compatible? and, if so, will the included documentation be suffucuent to wire it?
Thanks for any help.
