Duo Pan cam issue's
The Wyze Duo Pan Camera is a waste of money. It’s the worst Wyze camera I’ve ever had, with connection issues, loss of offset, and constant power cycles. The company does nothing to resolve the issue. I have three cameras with the same problem, I replaced them, and the same error persists.
Same I’m about to return mine. Junk
I’m curious: Are you using the power supplies that shipped with Duo Cam Pan? I’ve read about some people having problems with Cam Pan v4 connectivity when they were using under-powered adapters (like, say from a regular (non-Pan) Cam v4 when they were doing a swap), and ensuring that the correct power adapter was being used helped to solve those.[1][2] FWIW:
Model Power Adapter
Duo Cam Pan[3] 5V ⎓ 1.5A
Cam Pan v4[4], Cam Pan v3[5] 5V ⎓ 2A
Cam v4[6], Cam v3[7], Cam OG[8] 5V ⎓ 1A
  1. ↩︎
  2. ↩︎
  3. https://support.wyze.com/hc/en-us/articles/39550887791643-Wyze-Duo-Cam-Pan-Tech-Specs#:~:text=Power%20Adapter%20Output%3A%205V/1.5A ↩︎
  4. https://support.wyze.com/hc/en-us/articles/40185224761627-Wyze-Cam-Pan-v4-Tech-Specs#:~:text=Power%20Adapter%20Output%3A%205V/2A ↩︎
  5. https://support.wyze.com/hc/en-us/articles/11795670894875-Wyze-Cam-Pan-v3-Tech-Specs#:~:text=Power%20Adapter%20Output%3A%205V/2000mA ↩︎
  6. https://support.wyze.com/hc/en-us/articles/23746258989851-Wyze-Cam-v4-Tech-Specs#:~:text=6%20ft%20(1.8%20m)-,Power,Output%3A%205V/1A ,-Video ↩︎
  7. https://support.wyze.com/hc/en-us/articles/360051119371-Wyze-Cam-v3-Tech-Specs#:~:text=Power%20adapter%3A%20Indoor%205v/1A ↩︎
  8. https://support.wyze.com/hc/en-us/articles/18607971695003-Wyze-Cam-OG-Tech-Specs#:~:text=6%20ft%20(1.8%20m)-,Power,Output%3A%205V/1A ,-Video ↩︎
As said above, can you go into more details about any changes you might have used via hardware, I tested devices and still have not run into a single issue on this one. I can say that even running the stuff that goes before production ( which is pretty fool proof) Usually issues are known beforehand.
