The Wyze duo cam pan needs to be redesigned because if you tilt the non moving camera downwards, one that pans becomes unleveled and it’s either tilted way to the right or left just like seen it the picture, the higher I put it the more I have to tilt it down but that means the pan cam will tilt more counter clockwise which kind of sucks…in order for it to work fine the camera needs to be put at eye level which can be too low or on a counter or something…make that change to make it better please! Thank you!
