Double garage door control with one camera
Hello Team,
Are there any plans to use a single Wyze Cam v3 to control 2 garage doors?
The camera could be placed in the middle of the garage so that it “sees” both doors and 2 controllers could be used. I would buy it if this were the case. I can’t see using 2 cameras that are literally 10 feet apart from each other just to monitor the doors, seems like a waste and I know many homes have double garage doors instead of a big single.
Thanks
You should add this to the #wishlist if it doesn’t already exist. Make sure to vote for it!
Good call @IEatBeans. I have added it to the wishlist section and it was approved… I guess the way it works there is the most voted-on features possibly get put on the development roadmap?
If so, others can go here to vote (it would be much appreciated if this happened!)
Yup, generally the more votes the higher it will have to get picked for development. Wyze reviews the wishlist weekly.
Sometimes stuff will be moved to maybe-later if it is low priority it harder to implement.
Understood… We must be the only 2 here with a double door… :rofl:
I actually don’t have any garage doors, just a sketchy, leaky, squeaky, old barn door type thing lol.
I just think it’s a good idea for whoever does have 2 doors.
You can do it with a wyze plug and a dpdt relay. I just did this. Gives control, but you still only get notifications for one door. My camera can see both doors.
The way to do this currently is to buy 2 GDC systems. The main issue is the GDC only has 1 output, and that is either open or closed (button pressed). So it currently can only open one Garage door, or with extra wiring by you, 2 garage doors at once (not recommended).
This doesn’t help, as the current system can only control 1 garage door. Only one QR Code sticker is provided with each controller, so only one should be visible per GDC. If you buy a second GDC, please be sure only 1 sticker is visible. :slight_smile:
