Please change the viewing angle to point more downward. I would like to see the porch not the sky. This would let it detect package delivery much better
Hopefully, this can be done with a software update. Or have a kit to angle the entire doorbell down.
I made my own:
I wouldn’t expect a software update to resolve this kind of issue. This is a physics/hardware problem based on where the camera is pointed.
A kit would be nice, but then how do they decide what angle(s) to include? 3D printing seemed like the best solution for me, and it was something I was able to accomplish through my local library.
This is what the Duo addresses with its 2nd camera. I can see even the bottom of my front door.
That looks like what I was going to design and 3D-print until I found an existing design that includes a cover for the microSD card slot and decided to modify that, instead.
For future reference… (click to expand, if interested)
If you want to post a link like this but have it look less spammy, then getting rid of all the marketing/tracking information makes it much neater:
https://www.etsy.com/listing/1599567147
You can also format it as a hyperlink with text:
[Wyze Doorbell V2 Vertical Tilt adapter ](https://www.etsy.com/listing/1599567147)
