Is there a way to include the camera output from the doorbell pro cam in with the veiws of the others camera on the network in the app?
At this time, you can’t put the VDBPro in a “Group” nor can you stream it to the Webview, nor can you add it as a security camera to the HMS “Security Camera” Grouping.
The only potential option is to see if a 3rd party solution like “Tiny Cam” on Android supports using the Video Doorbell Pro, and then be able to stream it in a group through said 3rd party software. Though this workaround would not be recommended by Wyze (since they cannot guarantee security, etc of using 3rd party solutions).
For now it basically has to be viewed separately.
