Doorbell connectivity & DHCP
I had several issues with my doorbell, mostly solved when it was replaced by Support. It is now working fine.
One issue that I came across was to do with IP address allocation and DHCP. I don’t know actually how this works so the following is a ‘best guess’ that seemed to solve my problem.
When the doorbell is installed it gets its local IP address via your phone from the router from a DHCP pool. Routers recycle that pool from time to time. What seemed to be happening was the router would release the IP address from the pool at the end of the lease (I think) expecting a renegociation by the clients and a reallocation. But the doorbell doesn’t renegociate. It keeps the original IP address. The router may then assign the same IP address to a different device - and then bad things happen.
I solved the issue by connecting the doorbell via a separate wireless AP with its own differently configured DHCP range so there aren’t potential conflicts - and there may be other ways.
Anyhoo, it worked for me.
Many routers will allow to to assign a static IP address based on the Mac address of the device. If the doorbell isn’t checking for a new assignment, this would need to be set up in the router prior to the first connection.
Two notes:
  1. The phone has nothing to do with it. The IP lease takes place between the device (the doorbell) and the router.
  2. If what you report were true then there would be a serious defect in the way the doorbell handles DHCP. Routers give a specific lease time for an address and the device must renew it periodically.
I’m wondering how you determined the doorbell still had the old address. In my experience home DHCP leases are very stable and almost never change, even without “reservation” table settings.
The doorbell connects to the network authenticating via the phone ap. The Device Info says what the IP address is. That was unchanging.
This isn’t a home router.
But, hey, what I did fixed my problem. The MAC address route would have too if I had thought of that, but there was a customer-use AP available and that route fixed it for me.
Alright, folks, let’s resurrect this topic before I end up going full ‘tech support hotline’ on them, no offense to our dear support crew! :wink:
Am I the only one witnessing the comedic saga of the Wyze Video Doorbell Pro doing its DHCP dance? Seriously, I’m sitting here with my popcorn, watching this in real-time…
I’m rocking a UniFi Dream Machine Pro SE, and I’ve created a VIP (Very Important Doorbell) VLAN/SSID just for this little troublemaker to avoid any DHCP showdowns. The DHCP lease expiry is set to a generous 8 hours (I’ve even dabbled with different settings, folks), but this thing just won’t commit to an IP address. It’s like it’s auditioning for a role in ‘IP Address Shuffle: The Movie.’
And I tried to ground it with a static IP (seriously, what was I thinking?). But guess what? It decided to play the ‘IP Hokey Pokey’ instead. ‘You put your left IP in, you pull your left IP out…’
The doorbell boasts the latest firmware, v1.0.73, because, you know, we like to keep it fresh.
Now, before you ask, all our other DHCP devices are model citizens. They hold their leases like pros, renewing them just when they’re supposed to, not every second, like our mischievous doorbell here. Talk about being an overachiever in all the wrong ways, right? :smile:"
But, folks, let’s not forget the bigger picture here. I’ve got the gear and know-how to tackle this conundrum. The average user, though, they won’t have the same knowledge or hardware to set things up like I (we) have. Imagine the struggle they’re facing, all thanks to our ‘doorbell on the move.’ We’re here to help each other out, so let’s solve this mystery and save some sanity for our fellow users!"
Experiencing this currently with my Unifi gear and the video doorbell pro.
I suspect Unifi rolled out an update because now I get notifications to my phone saying that it’s exhausting my IP address range. It’s only because the doorbell does the dance soooo frequently that the Unifi gear can’t seem to keep up with the craziness.
Something I didn’t really think about is that it seems to be the Chime that connects to the WiFi and the doorbell connects to the Chime. The Chime behaves like a bridge. I’m going to play around with placement of the chime too.
