I received my Wyze Doorbell camera and started to follow the instructions to disconnect my chime. However, it appears that the metal is soldered and I am unable to “unscrew” anything to bypass my home chime. Is there a way around this?
can u cut the wires & splice to the fuse?
I was hoping not to do something like that. Is there a way around the issue?
not really, you need to bridge the wires bypassing the chime.
I guess the only alternative I can think of is running a new wire from the transformer to the doorbell if it’s even feasible.
If you cut the wires, just leave enough slack in case you need to reconnect.
Thanks for the info. I was afraid of there wouldn’t be a work around.
