Doorbell and other cameras toooooo sensitive
I have turned the sensitivity way down ( to the least)… and it still is trigered by cars 50foot away day or night…(any everything else every few minutes)…If I turn off notofications door bell will not ring…
I even set up a small detection zone that did not work …
I spent a ton of money on this system and at this point I want to retun it…
thank you for any help…
Which wyze device(s) are you talking about?
Have you had wyze cameras before?
If there is motion within the detection zone, it will trigger an event if it enough pixels change in the pre-determined time period. Exclude the area you don’t want from the detection zone, that is far more effective than the sensitivity.
I agree that did the same as david66. I had the Doorbell V1 no real issue and then I upgraded to a Doorbell V2. No matter what sensitivity or detection zone it was detecting motion at most all things.
Same here. I reduced the sensitivity as low as possible. Put in a VERY small detection zone and the thing still beeps with every car 40 feet away.
