When the Doorbell Pro is installed using the power from the existing hardwired doorbell IAW instructions the old ringer over heats and smokes. I see two required documentation changes are needed on the install for Doorbell Pro.
- Bypass Existing Hardwired Doorbell
WARNING: There is a smoke and fire risk the this is not done!
Open the Ringer box. Disconnect on if the wires and add it to the other wire connect bypassing the ringer completely.
After the Byass image
- For a Doorbell Pro hard-wire install the old ringer/tone box will no longer function. You must use the Wyze Chime box.
