Dont buy Wyze cameras
I would not recommend Wyze cameras as they appear to deliver software packages that render the SD card obsolete and says to check if your SD is properly inserted. I have 4 Pan Cam V3 cameras and all are equipped with quality Scan Disk cards that are rated for out door indoor use. All 4 cameras gave an error code after an update after the warranty period was completed. I went through all the trouble shoots and called customer service which are just call takers and listeners, meaning nothing was done. No follow up and no solution. This is in my opinion a direct pipeline to force the consumer to buy there outrageous priced data packages to save the footage and take the control out of your hands, yup it’s pretty dirty bussiness and I will copy and paste this to consumer reports to investigate. I have 4 cameras all with the same issue so the odds are that a service update was installed telling the SD card to malfunction. There is no other explanation and Wyze doesn’t want to make it right.
“Scan Disk” is a fake brand intended to trick you into thinking they’re genuine Sandisk cards. Sandisk is the most counterfeited SD card out there, even when they have the correct brand name, there is high risk that they’re a small card disguised as a bigger one.
No doubt there is some sort of issue with the Panv3 and SD cards. While my Panv3s (3 of them) have never given any issues, it is unlikely all the complaints are strictly related to the cards or power supplies, etc. I know Wyze is still actively trying to sort it out. Note that all my Panv3s have run every firmware and Android app released since mid 2023, and they’re still running the same Samsung High Endurance cards that I bought at that same time. From what I can recall I’ve never even formatted the SD cards in them, maybe once in one cam when trying to troubleshoot something years ago.
But in your case, it is the cards being used that is the problem.
The whole “they’re doing this on purpose to force you to subscribe” is played out, don’t bother trying to push that narrative.
Heck I was in Walmart last night picking up motor oil and happened to see a display of Wyze cameras, they had the Panv3 on clearance for like $20. If it wasn’t sold out, I’d have grabbed another one.
There are LOTS of people who have reported uSD card issues with Pan V3 cameras - FAR higher failure rate than any other Wyze cameras. As far as I know, no one has really come up with a reliable solution.
The only solution that is sure to work is to buy a replacement camera or have your camera replaced by WYZE (while supplies last) before the warranty expires.
You buy FAKE cards and blame Wyze for it, right?
I have never bought a MicroSD card from Wyze, but I buy quality ones from Amazon. I have purchased more than 20 Wyze Cams to date and none of them has had a problem with micoSD card ever.
Instead of advising us, ask us for advise on the right cards to purchase.
Your problem obviously is not the cameras, but your microSD cards!
But hey, if anyone believes Wyze cameras are not for them, noone forces you to buy them. There are so many options out there. Just keep your negativity and misfortunes in a safe, because there are many of us who are happy and swear by Wyze cameras!
There is firmware glitch that is infecting the sd card feature on the v3 cameras its been a few weeks now. I even spoke to a supervisor and she “IF theres solution”. So this may or may not get fixed. And wyze unfortunately are refusing to replace them.
@carverofchoice are you aware of this?
I have heard multiple people reporting SD card issues. I haven’t experienced any myself, but to be fair I don’t use Pan V3 cameras which are the commonly reported camera model issue. It’s one of the only cameras I gave away to my brother and don’t use myself anymore.
I have nearly every other camera model, 80+ total cameras, many since back in 2020. I haven’t had any of the cameras ruin any of my SD cards yet though. I mostly use SanDisk 128GB cards, but I also have other sizes (bigger and smaller) in some cameras, and I also have some other brands including the Wyze ones, and Samsung. Most of the 2K cameras use High Endurance SD cards, but all my 1080p cameras use non-high-endurance cards and have been cranking away on continuous recording for 6.5 years with no problems.
So…I am pretty certain there is not any conspiracy.
But I also believe everyone who has been saying they are getting corrupted cards, especially with the Pan V3. There are too many reports on the Pan V3 cameras to doubt it. But yes, some reports are certainly people using cheap cards or buying scam cards. For example, some scammers will buy REAL Sandisk or Samsung cards, remove the real chip inside it and swap a scam card into the case, then repackage it and go sell it on Amazon or Groupon, etc. It’s a huge issue going on lately. But while there are some people that applies to, there definitely is an undeniable pattern that points to there likely being some kind of Wyze firmware issue in some of the camera model versions like maybe the early Pan V3 models for some people.
I just don’t have much to say on the issue because I haven’t been able to confirm any SD card issues at all on any of my 80+ Wyze cameras. They’re all working. :person_shrugging: But I know people reporting issues who are completely credible, so it’s definitely something going on. Wyze is investigating currently:
Guys really, think about it the odds of 4 cards bought at different times failing at the same time is an unrealistic probability. If that were the case I should buy a lottery ticket and tell myself its the one and bring home the cash. I pulled the cards did an in depth deep dive into the cards validity and it is the real deal. I back dated the updates to early 2025 when the software was working and tried to unlock the devices and upload the old software and ran a check on the SD card the card is fine. Its one of 2 things a major software issue that locks out the SD card or a wiring issue inside the camera. I also tried reformatting the 128 GB Scan Disk Extreme cards to Fat 32 from exfat and ran a diagnostic. The cards worked perfect on my newer laptop and then failed when reinstalled in the Pan Cam V3. Either way it a WYZE issue, I have several tech support notes and photo’s on file and no comments on a fix or replacement as i am outside the warranty period. Others are reporting the same issue, since the cameras are useless they will be going to the Eco station and I will just add more cameras from Telus that have not been giving me any issues. I guess if you buy cheap crap this is what you get, lesson learned and ya I’m pissed off and hopefully this reaches enough people to think twice about buying these things. And if you don’t like that I’m posting my real world experience about this product and me spending 5 hours trying to figure out every possible work around too bad. If you had no issues then great good for you. Also the cards did work fine up until the recent updates and somehow it did something as I can not even back date the software as I was able to find earlier versions that did not take even with hard resets. Older cameras are not having this issue and I’m using the same card. I rely on the camera and equipment to do its job, not me having to play Mr.fix it. The software should be properly back tested before it rolls out to the consumer. It is useless if someone gets injured on my property or something gets stolen and I have no evidence to provide the authorities.
Scan Disk is NOT the real deal. It is a 100% fake brand.
The new firmware seems to look harder at the card for issues and if you have 4 fake or failed cards, you’ll get 4 failures with the new firmware.
I have 3 Pan v3s with 3 Samsung Pro Endurance 128GB cards bought direct from Samsung and they’ve been running 3.5 years with no issues whatsoever. Yes there does seem to be something related to firmware going on that affects some users, and nobody has quite been able to correlate why it affects some people but not others, but in your case, using fake cards is 100% your issue, nothing to do with wyze, the new firmware just exposed something that probably wasn’t working right before anyway.
If you’re looking for that kind of reliability and security, don’t buy $30 wireless cloud cameras (or even overpriced cloud cams like blink etc), get a true hardwired security camera system.
If you really think the firmware caused this, you can load this older firmware from before any SD card changes were made (this is also from before RTSP was added, I don’t think that one is downloadable).
https://download.wyzecam.com/firmware/Panv3/recovery_wyzepan3_4.50.15.5336.bin.zip
If the original SD card fix firmware from March (which also has RTSP) didn’t cause issues, that one can be downloaded at
https://download.wyzecam.com/firmware/Panv3/recovery_wyzepan3_4.50.16.5654.bin.zip
I can explain this, but the short version is that @dave27 is right, those cards labeled “Scan Disk” are counterfeit knock-offs designed to look like legitimate SanDisk cards. No major brand or supplier makes them, and they are notorious for causing data corruption.
At least in your particular case, the issue isn’t actually the camera’s firmware update or the camera ruining your cards…it is the cards themselves. MicroSD cards labeled “ScanDisk” or “Scan Disk” are counterfeit knock-offs designed to imitate legitimate SanDisk products.
The exact behavior you are seeing where the card successfully formats on a computer and seems to work initially but crashes in a smart camera is the textbook hallmark of a counterfeit flash memory scam. Here is exactly why this happens and how the card is tricking your computer:
Formatting Trickery
When you connect the card to a computer and hit “format,” the computer does not scan or test the physical storage cells.
  • The Lying Firmware: A microSD card contains a tiny micro-controller chip alongside the actual storage silicon. Counterfeiters hack this internal controller’s firmware so that it is hardcoded to report exactly “128 GB” whenever a computer asks for its size. But it is lying.
  • The Quick Format Illusion: When a PC or Mac formats a card, it simply deletes the existing index table and creates a fresh, empty File Allocation Table (FAT/exFAT). The computer assumes the card is healthy because it hasn’t actually tried to write 128 GB of data yet, it just reads the fake “128 GB” label provided by the hacked controller.
Why it Seems to Work in Other Devices*
If you put the card into a phone, a tablet, or a computer, it might seem to work fine at first if you are only transferring a few photos or light documents. As long as the total data you put on the card stays under its true physical limit, the card will behave normally. The moment you cross that invisible line, your data will vanish or corrupt.
Why the Smart Camera Immediately Crashes It (when other devices don’t)
Unlike a computer or a phone, a smart camera treats memory cards with extreme intensity:
  • Exceeding Real Limits: The actual underlying storage chip inside a fake “128 GB Scan Disk” card is usually just a cheap, rejected 4 GB or 8 GB piece of scrap silicon (there are examples of swaps at 32GB though with an added modified firmware, but most counterfeits are often 8gb or smaller). A smart camera continuously streams high-definition video, meaning it fills up that real 8 GB space within just a few hours.
  • The Crash Trigger: When the camera tries to record past the real 8 GB limit, the hacked controller has nowhere left to put the data. It either starts silently wrapping around and overwriting older video files (which corrupts the entire file system) or the card’s controller locks up entirely.
  • Why Did this Start After a Firmware Update? Smart camera firmware updates frequently introduce stricter stability checks, higher video bitrates, or changes to how data is continuously cached. This extra data strain immediately overwhelms the low-grade, defect-ridden silicon used in counterfeits, causing the camera to flag the card as failed.
    • Ironically, Wyze may caused this issue by purposely making improvements to the SD card reader that force it to have improved functionality and stability checks, or other improvements, which exposes and ruins a counterfeit card like this very quickly. This could actually be evidence of the opposite of what people think…Wyze’s recent improvements to the SD card reader with firmware updates may actually be causing more corrupt SD cards specifically because they improved it to be more stable and reliable and function better with real SD cards that aren’t using modified firmware and scrap silicon to fake what it reports. It would be wildly hilarious if the cause of the recent epidemic of corrupt SD Cards isn’t because the SD Card reader in the Camera is bad, but it could actually ironically be because it is too good and thus ruins fake SD cards. :rofl: That would be hilarious. I wonder if they would consider undoing the improvements to make the SD card reader worse so it will be more compatible with counterfeit cards again. I would die laughing if it ends up being this as the explanation and outcome. But it would make sense why so many of us who buy SD cards direct from the manufacturers are not experiencing this, while others are having it happen to all their cards.
How to Prove It (The Ultimate Test)
You can easily prove the card is defective right from your PC using a free hardware verification tool. These utilities physically write unique data to every single sector of the card and verify if it can actually be read back:
  • ValiDrive (Fast 2-Minute Test): Download ValiDrive by Gibson Research Corporation. It performs a quick spot check across the card map and will visually map out exactly where the real storage ends and the fake firmware scam begins.
  • H2testw (Full Sector Test): Download H2testw. It will write to the entire card and give you a detailed log showing its true physical capacity.
Most likely, to keep your camera running smoothly, you will need to replace the fakes with genuine cards purchased directly from authorized retailers that don’t allow for 3rd party listings, or go through official brand storefronts. I highly recommend getting cards specifically rated for continuous loop recording, such as SanDisk High Endurance or Samsung Pro Endurance.
Avoid anything spelled differently in any way. Common scam card names are • “ScanDisk”, “Samsong”, “Samsumg”, “SamDisk”, etc. But even getting one that says “SanDisk” or “Samsung” correctly isn’t a guarantee if you bought it on Amazon from a 3rd party lister or Groupon, or Aliexpress, Temu, TikTok Shop, or lots of other places. Many scammers buy real cards, swap out the real case with a counterfeit fake and sell it at a still discounted price for a huge price.
Now I’m really curious if most or all of the recent SD Card epidemic is due to counterfeit cards. It would explain why it’s only happening selectively. I’ll have to start asking people what card they are using and where they got it. I wouldn’t be surprised if the issue is the Wyze camera breaking the counterfeit SD card modified firmware. Might need to ask people to try using one of the above tools on their SD card to verify it’s not faking the storage size.
For anyone else having this issue, please try the above tools and show the results along with where you bought the card, etc. It will be interesting to see how many people having this issue turn out to have counterfeit modified firmware on their SD cards. Counterfeit cards have been a major epidemic lately.
(Note, I still think it’s possible some Wyze cameras are corrupting legit cards for some people. I can’t replicate the issue, and just because one or more users experiencing corrupt cards turn out to have counterfeits, doesn’t mean that applies to everyone having this issue. We need to give everyone the benefit of the doubt while proper testing is executed and demonstrated)
To second this, I would only buy cards “shipped and sold by” Amazon and when you receive them, ensure there isn’t a white sticker with barcode on it (which means they sent you stock from a 3rd party, which they sometimes do). If it has that sticker send it back. I’ve had this happen with memory cards but also batteries which are commonly counterfeited. If they have a white sticker, I send them back without even opening. Supposedly Amazon has stopped the “comingling” of 3rd party stock but I’ve seen it happen as recent as 6 months ago, so if they have truly stopped, it will take a while for them to get through that already mixed stock.
The alternative is to buy from the manufacturer themselves, as they often have the same price and free shipping, or a brick and mortar store like Best Buy or Staples. You can still buy online from those stores, don’t have to go in and buy in the store. Just again make sure you’re buying from them direct and not a “marketplace” or “3rd party” seller.
This is one of the rare cases where I agree with AI :slight_smile: Given the posts here of people having multiple cards stop working after the latest firmware makes me suspect they did exactly that, probably to try and make it so a fake or defective card will fail right away, rather than randomly.
That’s what is making this so difficult. I’m willing to bet a significant portion of the SD card issues are due to fake cards, but another portion is from cards that are just cheap and can’t keep up (Kodak cards have been discussed in another thread, they can’t handle read and write at the same time), another portion is from cards that are legit but have just hit the end of their write life or died for other reasons. BUT there does seem to be a component of this that is hardware or firmware related. There just doesn’t seem to be any rhyme or reason as to who is affected by that or why. I haven’t seen it at all, you haven’t, @crease had it on one cam but not another. It makes no sense. There is some weird combo of things that seems to trigger it. A certain batch of cameras, maybe using the internal formatter on certain brands or capacities of cards, who knows.
The other wrench in the works is user error/misunderstanding. I’ve seen people post that they’ve forced a FAT32 format on a card because they read somewhere it is better. That will kill the performance in these cams due to the large number of small files which FAT32 sucks at, especially when you get over 32 gigs. exFAT is the way to go, heck I might even say use it for 32GB and smaller too.
But obviously when someone has a card fail and sees other posts about it, they’re going to assume it is all one single problem with firmware or the Panv3, when in reality that’s only the problem for a certain percentage of the users.
This issue is exacerbated by the fact that SD cards are insanely priced right now and more and more people are looking for cheap alternatives and turning to Ali and/or lesser known brands.
I’d say the lowest I’d go is PNY - and I probably wouldn’t trust those on continuous. Lexar makes good cards and are highly regarded with photographers, but I don’t know how they’ll do in one of these cams, I’d assume fairly good. A step up from PNY, but still may not handle continuous for very long.
Kioxia is a crap shoot. Seems like some of their stuff is fine then they’ll produce a lousy batch. Very hit or miss. I’d consider it probably a step down from PNY and not worth it.
Lexar used to do white label cards for many brands (I suspect the Wyze cards may have been Lexar at some point). But Kioxia has now become popular for that due to their lower price, so it is possible the Wyze cards may now be Kioxia. The Kodak cards may be bottom of the barrel Kioxia ones, basically scrap that they couldn’t use for other cards. The only way to know is use software to pull the vendor ID off the memory chip, and since I don’t have any, this is just educated guessing.
One thing I like about the Samsung cards is they have a utility that can validate if it is genuine or not. Though I suppose it is probably possible to trick that utility too.
Since you brought it up…
Longsys acquired Lexar from Micron Technology (one of the best/only chip manufacturers) in 2017 and has since re-established Lexar as a prominent consumer and professional brand for microSD cards (and other things), but they appear to tbe the same supplier that makes Wyze SD cards (Public Shipping records show Longsys is the company shipping Wyze their MicroSD cards). Therefore, like you mentioned as well, it is also my belief (based on public information) that Wyze SD cards are basically just rebranded Lexar SD cards. And since Wyze SD cards work well in Wyze cams, I am pretty highly confident that Lexar SD cards work well in Wyze cams. :+1: But it is totally possible that Wyze asked Longsys/Lexar to use a specific type of card for their cameras, and it’s possible that SOME Lexar cards aren’t built to handle continuous recording while others are and Wyze just picked the kind to be used that would hold up well with continuous recording. But I bet there is an exact Lexar Equivalent that has the exact same internals just with a different casing instead. But Micron makes great high quality products, and Longsys bought Lexar from them and Wyze [apparently] sources their cards from them (no employee has told me this or confirmed it, I just used deduction because of the public shipping records saying they were coming from Longsys and Longsys is the owner of Lexar).
I haven’t checked the public shipping records recently, so it’s always possible.
You might be one of the first other people I know who figured out Wyze was PROBABLY rebranded Lexar since that was their supplier.
How did you figure it out? I already said I figured it out from the Public shipping records.
I would like to mention regarding the fake cards are the issue, I was using a SanDisk sd card on mine
In my case nothing near as concrete as you did, just educated guess based on the fact that Lexar was pretty much the only one doing white label cards for a long time, I have several white label cards from dash cams and other things and the vendor ID on them all came back to Lexar. But then I read a year or two ago about Kioxia starting up a big white label program so not sure what the state of things is at this point, and/or if Lexar has stopped doing the white labeling after the change of parent company.
Every brand of card has a range from low to high end. I like the Samsung cards I’ve used but have found that the standard Evo cards will NOT hold up to continuous recording for very long. The challenge with the white label cards, as you say, you don’t really know which level of quality the company chose.
My dash cam cards (confirmed Lexar, and only 8GB) which I never actually used in the dash cams, have been used in 3 OG cams for event-only recording and have stood up for 3.5 years in that mode. Have never attempted continuous, but a couple of them record probably 20-30 events a day. I suspect they and Wyze probably both told Lexar to use something with a reasonable amount of endurance, otherwise they’d just end up with a lot of unhappy people, support calls/costs, and warranty claims. They don’t need high write or read speeds, just decent endurance and the ability to read and write at the same time.
I have several of the Pan V3 cameras and I’m not having the SD card issues that many people have been describing. I’m wondering if they’re purchasing high endurance cards that are rated for continuous rewrites. I see people saying they’re buying “high quality” or “high end”, or cards rated for “indoor/outdoor use”, but I hardly see them stating they’re using actual high ENDURANCE cards.
Wyze already stated that not all devices are infected. Im using SanDisk and looked up to see if it matches all of wyzes sd requirements and it does
I know not all devices are affected, hence why I said “that many people have been describing.” I was simply pointing out that there’s a difference between using a high quality SD card and using an actual high endurance card rated for continuous recording and rewriting. SanDisk and other brands make several types of microSD cards, and not all of them are endurance-rated.
Right tools for the job. Although currently very expensive. Glad I purchased when very affordable. :grin:
There are a number of factors at play and that’s what makes it so difficult to resolve. Many of the issues are no doubt related to the SD cards themselves and/or user error. There does definitely seem to be some issue with firmware or certain revisions of the hardware too though. At this point, nobody has figured out the exact correlation. I’m lucky that all 3 of mine have been fine, I am using endurance rated cards, but even a non endurance card will work for a while (some of them quite a while). Some people are having issues with brand new cards. Some of those cards are fake or defective, but there are too many reports for that to be the full explanation.
