I have been waiting for buying replacement for my old sensors.
Should I change to other band? If yes, any suggestion??
@alwaysmarco Welcome Back! I currently donāt have any suggestions for other brands.
@WyzeJasonJ Answered this question a couple days ago in this post here.
Is this referencing the ācontactā sensors⦠(ie. door or window use)?
I need to replace my āmotion sensorā that came with the contact sensors ⦠it died after 2 yrs of use.
Any idea when/if they will be available to purchase? If so, is there a way to be notified ⦠support wasnāt any help on answering these questions. Would have been nice if they could have put me on the list if one existed.
Thank you
All v1 sensors have been discontinued by Wyze. You may be able to find a v1 motion sensor on eBay.
I havenāt heard when the new v2 contact & motions sensors will be available by themselves. They are currently only available when you buy the Home Monitoring Bundle. You can add extra sensors to the bundle before you check out.
āAll v1 sensors have been discontinued by Wyze. You may be able to find a v1 motion sensor on eBay.ā
Thatās a shame, guess Iāll have to devise another security setup.
TY for responding.
UPDATE: now Iām being told they will send a replacement ⦠Iām hoping thatās the case.
