**Doe fhe Wyze motion sensor work through clear glass? Mine is inside looking toward my driveway outside.
Thanks,
Thomas (Tommy) Toles
Jefferson GA
P.S. I type so badly because I have Paarkinson’s Disease.
Thanks,
Jefferson GA
What Wyze motion sensor? For the v3 cam? It detects movement and people/cars just fine through a window. I have one aimed at the street from the upstairs window.
Camera motion, probably. Motion Sensor (V1,V2) not so much. The motion sensors are infrared and detect heat differences. The cameras detect changes in pixels in the viewing area to find motion. (Exception is the outdoor camera which uses a combination of both, I believe.)
Thank you!
Tommy
