I bought 3 Wyze Cam V2 and they work very well with the cloud. Events are registered on the cloud and I can see them in “Events”.
There is a Wyze Can I installed a 32G micro SD card. In Local Storage, I configured the card, formatted it, and set it to “Record events only”.
But when I go to View Playback, I do not see any recordings.
Can you help me?
Can you try to set it to continuous record and see if you get any video saved to the card?
Also, don’t rely on the green bar to accurately represent video on the timeline. Mine routinely has blank (no green) that contains video (continuous record mode).
Thank you to all of you. I finally found the problem. This is my micro SD card that had a problem. I changed the map and everything works now.
