Disabling RTSPS screen
I am trying to disable the RSTPs security and I can not get past this screen. I feel like it should scroll down but it does not. I tried everything (even connected a keyboard and hit enter). I also tried this on an Ipad and that worked even worse. Does anyone have a solution ?
Have you tried to set your iOS device display zoom to default instead of large. ?
that worked thanks
Great
smiley
FWIW, I saw another iOS user report this earlier this month:
Thank you, @Antonius, for providing a solution! :+1:
Welcome to the Forum, @Bsmith! :wave:
Setting an iPhone display zoom to default also helped a lot when trying to set up a cam that required you to scan the QR code like for a V3. I think most cams use Bluetooth now though.
I’ve read that here, too, but this is the first time I’ve seen it solve the RTSPS screen hurdle.
