Direct Unlock toggle is gone
Hey everyone,
I was using my Wyze Lock Bolt with my Wyze Video Doorbell Pro, and the remote unlock feature was working fine. But after my doorbell froze, I had to reset it. Now, when I go to add the Wyze Lock Bolt under Accessories in the Doorbell Pro settings, the direct unlock toggle doesn’t show up. It just says “Loading…”, and when it’s done, backing out shows “No devices” linked.
I’ve tried:
Updating firmware for both devices
Power cycling both the Lock Bolt and Doorbell Pro
Removing and re-adding both devices
Clearing the Wyze app cache
Checking for app updates
Still no luck. Has anyone else had this issue? Did Wyze remove the feature, or is there a fix?
Thanks!
I have confirmed the feature has either been removed or has been broken in the Wyze App itself on version 3.3.5.623
I have also tried to get this working and can confirm it just says loading, then doesn’t add my lock to the doorbell.
Have you been able to re-add your lock? Does unlock via the feed work for you anymore?
No. Can’t readd the lock. I can see in in the accessories menu, but clicking it says loading, then nothing. I spoke with support, none of their troubleshooting methods worked, and was told that I should just keep trying ocassionally as they release firmware updates sometimes… Twas’ very helpful.
Hi Could you please provide me a devicelog for doorbell pro after adding failed? Thanks!
Sure, check logs:
1763459
1765209
I can try and readd it again later tonight when I am home then upload the log.
I tried on mine with no luck. I provided @WyzeDesmond with my log files as well.
Has anyone noticed in this version of the Wyze app you can no longer unlock the door at ALL via the Video Doorbell Pro feed? This is horrible :cry:
Wyze is looking into this. I will see if we can get a status update
A month has passed with a new Wyze App version available but this advertised feature is still fully broken. Any update?
For those looking for a temporary fix do not update the app past 3.2.2 where it still works properly.
No feedback yet
It still doesn’t work with Wyze Lock Bolt. Just says “Loading…”
I do have both locks and for the Wyze Lock (wifi version) this feature does work.
Potentially this will be resolved in a future app update, along with a related issue:
:crossed_fingers:
Can you provide an older version of the app where the functionality works?
I cannot, but sites like APKMirror or APKPure can. It’s even possible to use current and older versions of the app on the same phone at the same time.
