Differences Between iOS and Android Apps
New Temp / Humidity Sensors:
  1. Notice the difference in the Graph when you drill into the Temp. Screen
  1. The Settings screen for the temp sensor is missing Wyze Support option in iOS.
Looks like a flat out sampling rate difference. That can’t be good.
Seems like their sampling rate would be done on the device itself, so it’s got to be something to do with just the measurements in the graph rate for each device. Probably the average of the samples taken by the device which would be on the app
