New v4 user here. I have the cam plus cloud storage. I want to set a Detection zone that blocks out the street. Then I would like to insert an sd card which would record everything for the past 4 days including the street. Will that work? Thanks.
One has nothing to do with the other. So long as you select Continuous Recording under SD Card, it will do just that.
The detection zone has no bearing on what the camera records either to the cloud os SD card. It is solely used for notifications mostly. You are good to go.
