Detection and Lighting Tips for Flood?
So, just installed the flood last night. I’ve got a bunch of other wyze cams already, but the flood seems a different beast.
I keep getting motion alerts that aren’t desired. I know one of the problems if a flag I have hung off to the side that gets caught by the motion detection, so I use detection zones to try and eliminate the false positive.
However I think with the PIR sensor on the flood itself will pick up the flag, cause the flood to turn on, which then brightens the picture and triggers the camera motion detection.
What do most recommend? Right now I set the flood to only trigger off camera detections, but seems silly to cut out the PIR sensor entirely. I guess adjusting the camera angle (catching less of the driveway) or moving my flag are other options. Also not sure if maybe just bugs flying by the camera are also triggering it.
