I have wyze locks on most of my doors including two Palm scanners and they’re great but the one thing that’s missing from your inventory is a deadbolt that has the deadbolt on both sides. For doors with windows or Windows right next to them you need a deadbolt that can’t be turned from the inside. Every deadbolt you provide now can easily be circumvented by someone breaking a window reaching through and opening the lock. It would be great if there was an option to remove that manual mechanism and replace it with a key or another sensor on the inside
