Daisy Chain
Hello Everyone,
I would like to know the maximum amount of distance I can place one camera away from its power source (using regular usb cable)?
Also, If I would like to add another, how far could I extend it, using one power adapter? (no crazy hardware, just plain usb cables)
From my experience using the V2 cam, 1 amp adapter and 6’ USB cable…2 usb cables and 3 V2 cams. If more cams or longer cables the adapter needs to be 2 or more amps.
I believe the recommended max is about 26 feet for USB power only. I use this cable with no issues with the adapter sold with the Wyze camera. You could then use the included cable to daisy chain a second camera but that may require upping the amperage on the adapter.
25ft Power Extension Cable for Wyze Cam, Blink, Yi, Oculus Go, and More.
by Benair
Learn more: https://www.amazon.com/dp/B0763358FV/ref=cm_sw_em_r_mt_dp_U_Ey9xDbV4N0AM7
Please keep in mind, it is not recommended to do daisy chains with Pan cameras. Only V1 and V2 models. :slight_smile:
I honestly keep forgetting that point. I don’t have any Pans that are daisy chained myself, just 2 V2’s. Thanks for catching that oversight. The motor on the Pan adds to the draw, especially when in use so I am sure it can cause issues especially with edge cases.
You’re welcome! :slight_smile:
Do you have any firsthand experience of whether it works with a V2 daisychained to a Pan? I understand the increased power requirements, but I would use the Pan wall wart and we’re only talking 2 cameras here.
It’s best to avoid it due to power consumption. This support article explains daisy chaining Wyze cams.
