Hello, can an alarm frequency be added to the camera and software so that you can control the frequency of alerts when there is constant motion or sound for a time period. An example is if there is activity that triggers and alert and the activity continues for more than the 5 minute “cool down” period of the camera then another alert will not be sent until the this frequency period is met, such as do not send another alert until 15, 20, 30 minutes. Most common are unscheduled activities that trigger an alert that are not an urgent matter but that you want to leave the camera and alert setting on but do not want an alert sent until a time window is met.
I never had thought of it until today when I was out in my front yard and realized my phone had many notifications of me doing yardwork, but I can see instances where this could help
Maybe a shortcut to “mute” notifications for whichever cameras you need it for for a incremental time. kind of similar to the do not disturb feature on android currently.
mute x camera/s for 15,60,90, ___ insert integer here …minutes
Thanks, but that is not the same. The mute function does not
address the root of the alert. The user should be able to
customize the alerting frequency for a defined time window so the
alerts do not trigger, the videos are not captured, email if
enabled is not sent. it would be very helpful.
I would like the option to specify a minimum time between notifications. For example, no more than one motion notification every 15 minutes. So if a motion notification is sent, the app will not send another notification for 15 minutes (or 10, 30, 60 minutes, etc.).
This functionality should not affect event detection or recording, only notifications. And please, let the user determine the frequency; don’t try to choose it for us.
I see a lot of complaints about too many notifications, and the functionality that I’m requesting is a simple (and really obvious) solution.
I’m using the cam pan to detect if someone breaks into my home. I just need one timely notification that motion was detected (or that a fire alarm went off, etc.). I don’t need a notification every 5 minutes, because when I’m home I get way too many notifications.
The workarounds on the support site are to reduce sensitivity or turn off some notifications (e.g., sound); however, using these workarounds can lead to missed detections. Also, I don’t like turning off notifications during specific times of day, because then I have to remember to turn them back on if my schedule changes (e.g., going out of town). I just want a throttle on the number of notifications.
I cannot believe that this issue still exists without somebody clarifying why an interval time between notifications hasn’t been added. This issue may lead me to use a different brand of security camera.
I use my cameras to monitor foster cats, and a longer cooldown would help me immensely. I want to know when they’re out moving around, but I don’t need notifications every minute (sometimes multiple times a minute) after that. I know I can snooze the notifications, I just don’t see why I should have to, especially when so many users are requesting customizable cooldown periods.
I agree with the benefit of customizable notification cooldowns.
It’s a function available on one of my cameras, albeit with limited choices (1, 3, 5m), but I’d love at least the same options on my Cam v3 floodlight camera. It shows our driveway, and there’s no way the camera won’t tag you 2 or 3 times in the time it takes to leave or return.
A cooldown option from 1-3 minutes would solve this issue if we had to bring in groceries or pack things into the car for work, etc. I’m sure options for longer cooldown periods would be nice for others’ purposes. Quite a stretch here, but it would possibly be nice to add a change of that setting attached to a rule, so the cooldown could be scheduled to be different throughout the day.
I’ve been a Wyze customer for almost 6 years and this feature alone has me ready to buy an entirely different system. How obnoxious that I get 10 notifications within a few seconds for the same person walking to the front door. The “cooldown period” is already baked into the software as the “free” version has a 5 minute cooldown period, yet now that I’ve decided to subscribe I’m bombarded with constant, obnoxious notifications?
This is lazy coding 101 - it’s already a feature, and bugs the you know what out of PAYING customers, yet refusing to fix.
I would love to be able to change the frequency of alerts in a way that is not tied to sensitivity of alerts. I attached a screenshot of this feature from another camera platform. I don’t want to change sensitivity because then I would missed things but my use case is I have them in a room that has a lot of activity and might only want to get an alert every 10 mins vs every time someone moves
If you don’t have cam plus, then there is a max 1 alert ever 5 minutes. Unfortunately with cam plus I believe most of the cameras don’t let you adjust the frequency, only a couple of the battery ones allow that. So you need to use detection zone, sensitivity, camera angle, etc to reduce unwanted alerts.
You may want to post your request in the wishlist forum.
This happens for me also when I have a package delivered to my front porch. Basically, the AI is smart enough to know there has been a package delivered. But then any time there is any other movement, I think the AI/app triggers the alert again (not sure on the specifics but pretty sure any movement in the window you select for that camera). So basically any package in the field of view will constantly trigger notifications/alerts until the package is physically moved.
You are correct in that assumption, anytime there is movement triggered within the camera via pixelation change, the camera takes a screenshot effectively and analyzes that single photo for any of the known detections selected. Based on the known detection selected in that view it alerts you as to what is there.
That is the current setup. But considering the numerous reiterations of things with AI in the recent past Not giving any secrets away in any way shape or form whatsoever, I can’t say that things are being worked on to mitigate this. Definitely something to be aware of and follow up with. Feel free to tag me in and ask for an update. I will reach out to my friends in the company and see if we have any movement on anything.
Is there a way to set a cooldown for alerts on the pan v4/iphone app 3.11.0 (6)? I’ve checked multiple suggested locations, but I can’t find any option to do so.
The situation I’m looking for a solution for is someone walks in the room, I get an alert (expected), but every minute after that the person is still in the room I get a new alert. I’d prefer to not get a new alert until a new set of activity happens, but I’d be fine being able to set something that says “don’t alert more than once in XX minutes”
Thanks!
[Mod Note]:Your topic was merged to this Wishlist request for consistency in grouping similar requests and for better visibility to Wyze. Please remember to scroll up to the top and click the VOTE button to show your support.
