Convert percent detection to decibels?
For the Wyze software and OG camera, is it possible to convert percent sound detection into decibels?
Welcome to the Wyze User Community Forum @jcmiller! :raising_hand_man:
Are you asking for the units of the Sound Sensitivity Slider in the Detection Settings to be changed from 0-100 to be labeled in decibels instead?
Yes, or a conversation table.
Gotcha. Just wanted to be sure we were on the same page. I have never seen any documentation on the dB range for any of the Wyze Cams. However, what you are requesting is a feature enhancement.
If you would like to request that Wyze add this feature, that is handled thru a new topic post in the Wishlist. Go to the Wishlist, search the topics for one that matches your request. If you find one, vote for it at the top, like :heart: some posts, and add your reply post to support the request. If you do not find a match, submit a new topic for approval.
I did find one post in the Wishlist already that mentions this feature request. Perhaps posting your request as a reply there will meet your request needs.
Sounds good. Thanks.
