Having worked at the drag strip for a few years before being able to afford a real car (I took my Corolla down once, it was a 5 speed so I think I managed 19.xx seconds) I had all that pretty well down pat and even my very first run in a powerful car was pretty respectable.
My worst mess up was after I had souped up my 2001 camaro to around 500HP, including a very short throw shifter in a 6 speed which was very unforgiving, I shifted 3->2 instead of 3->4. Lifted the heads right off a little bit, unsealed the head gasket. I was able to limp it home. Had to drain the oil and coolant, replace the head gaskets (luckily metal ones that are very easy to swap) and flush everything out well. The ARP head studs and titanium pushrods I put in did their job, could have been a lot worse.
This particular track is in a lousy spot climate wise too, always very humid. One night there weren’t many people there so we got to make lots of runs without much cooldown in between. On my like 3rd run of the night, I had been sitting in the staging lanes with the A/C on, turned it off about 60 seconds before pulling up on the track (as you should do so you’re not dripping water on the track). By the 60 foot line the heat from the engine blowing across the windshield fogged it up solid. I had to turn the defroster on mid run and look for a change of underwear after.
We would constantly watch guys (and some gals) drive their front and rear tires through the bleach, then either do no burnout or just a little chirp. Then they’d get sideways mashing the gas right off the starting line. The worst was front wheel drive cars that actually did know what they were doing, they’d pull up spin a bit in the bleach, back up (which usually required the cars behind them to back up) drive around the water pit, then line up in front of it and do their burnout (at which point there wasn’t much water/bleach left on the tires). Slowed everything down.
These days they put so much glue down pretty much anyone can get traction even if they’re totally clueless. Even the track I was at that was notoriously stingy and was pretty much the only one nobody had hit 300mph at yet, nowadays your shoes will come off if you walk across it and a new NHRA trap speed record just got set there. Takes some of the fun/skill out of it.
