Connection. 1 loads, 1 very busy
Thanks for the info but I’m not using Wi-Fi I have my router right neqr the cams
As @dave27 said, interference. Maybe your neighbour is using his cordless phone, microwave…
What do you mean, you are not using WiFi? How are the cameras connecting than?
You’re in the wrong forum then, Wyze doesn’t make any wired cams.
Lol. I thought about that after I posted it.
Lol. I thought about that after I posted it. Couldn’t delete it
How frequently do you clear your cache(s) and/or when’s the last time you tried that? Sometimes when I’m seeing connection glitches, clearing that seems to help:
This is how I tend to clean my account caches on Android (click/tap to expand):
  1. Clear the in-app cache: From the Wyze app’s home screen, navigate to  Account ➜ App Settings ➜ Cache File Size ➜ Clear.
  2. Swipe the Wyze app out of the running Android apps.
  3. Long-press on the Wyze app’s launcher icon (on the phone’s home screen or wherever you tap to initially open the app) and then tap App info in the pop-up menu.
  4. Tap Force stop on the App info screen (may need to tap OK to confirm) and then tap Storage & cache.
  5. Tap Clear cache on the Storage screen.
  6. Back up one screen (back to App info) and then tap Open to re-launch the Wyze app.
Note: I don’t know what the options would be for modifying these steps on iOS since I don’t use that platform.
Sometimes I stop at just clearing the in-app cache, but occasionally I’ll do the OS-level app cache, too.
