Configuration for toggling on auxilary heating
Hi all,
I searched through the prior posts and could not find anything similar to what I am trying to achieve with my setup. I recently installed the Wyze thermostat and trying to replicate what my previous smart thermostat had. The prior setup had these 6x wires: C, O/B, RC, W/E, Y, G and would let me to manually select auxilary heat whenever I chose to. The system has forced air with a heat pump, which is the default heating source, as well as natural gas that is secondary and switches over automatically with a sensor when outdoor temperatures get to 10 degrees. I now want to configure the setup so that it works the same as my prior thermostat to allow me to manually select auxilary heat when I choose to. I ended up taking the wire that was formerly W/E and put it into W1, but I feel like that’s not the solution I needed. At the time of setup, it ran all the tests seemingly fine and set the heat pump as stage 1 heating (test successful) and natural gas as stage 2 heating (test successful). Any suggestions greatly appreciated, thanks.
I ended up getting my response by searching further and having found this thread: Thermostat - W/E wire? - #5 by manasheticsz1
All seems ok now, it passed the Wyze 2-stage heat test (1- heat pump / 2- natural gas), and it also created the “emergency heat” option in advanced settings via the " * " terminal. I formerly had a W/E wire and split it between W1 and the " * " terminal. I haven’t tested the emergency heat on a stand-alone basis yet, but have no reason to doubt it will work. (Luckily there is a good gap between the thermostat and the back plate; otherwise, I would not have been able to fit it with that wire nut)
