Color light bulbs crash
Anytime I open up a color light bulb and make a change, color or brightness, it makes the change but the the app freezes. They light bulbs and app are all up to date.
I have had this happen before. Try deleting and reinstalling the app.
Thank you that worked!
I added the Bulb BR30’s and Bulb Color and it crashes my app every time I make any change, create/edit a rule, or turn a bulb on/off via the app. The app has been solid until the bulbs were added. Running iPhone 13, iOS 16.2 w/ latest Wyze app
What did it for me was deleting the app and reinstalling. I was having a lot of issues with the app, not just with the lights. Now everything works great.
Great. I have three cameras, four plugs and four bulbs. You’re saying to delete the app and reinstall all the devices? A pain in the butt.
Once you delete and re install just put your user name and password into the app and all your stuff will still be there.
Everything’s saved on your account, so as long as you sign back in all your settings and devices will be the same
