Cleaner Air Available with Wyze Air Purifier - 4/12/22
You got Beta access back?! Congrats, here I thought you’d lost it (from it being full) for the foreseeable future :slight_smile:
I did!
I’m still a bit confused about the information on the display and in the app. So if the display shows say 001, I assume that’s the number of particles the laser has detected…particles per what? And why didn’t the put the laser sensor on the front instead of the back? Seems to me it would get more accurate data facing into a room.
Also, about the Indoor AQI History graph. I finally got two dots after moving the purifier to another room and both under the PM2.5 Health Guideline dashed line. I don’t understand why more dots aren’t showing up and what do the vertical numbers on the graph represent?
I figured out that the only way the App AQI and graph updates is if I unplug the machine and plug it back in. It updates once and doesn’t after that unless I unplug it again, and even then only does the update once. Yet the Outdoor Pollutants information has no issues updating. I also tried turning the machine off and on via the button but that had no effect. Definitely a software issue, like all of Wyze’s software based products have.
Hello, can anyone let me know when this Wyze AirPurifier will be available in Canada?
Anyone know when it will be available for sale again?
When asked on June 9th when the Air purifiers would be back in stock, Jimmy from Wyze said the following:
Thanks for the updates!
