Chime Compatibilty
Which chimes are compatible with the new Wyze Battery Video Doorbell? I have the chimes that came with the Wyze Video Doorbell Pro and the original Wyze Video Doorbell (Wired).
Welcome to the Forum, @jpeel1! :wave:
I believe Battery Video Doorbell gives you essentially 3 options:
  • Use the home’s built-in chime, with a few conditions:
    • The home has a built-in chime connected to a compatible transformer
    • The chime itself is compatible
    • Battery Video Doorbell is installed as a wired doorbell
    • Chime Controller is also installed
  • Use the Cameras as Chime feature with compatible Wyze Cams
  • Use Universal Wi-Fi Chime
Video Doorbell Pro’s Chime Pro is pre-paired to that particular doorbell camera because in addition to being a chime it also acts as a wireless gateway in order to provide Wi-Fi access to that device. That makes them exclusive to one another. The original Wyze Chime is compatible only with the original Wyze Video Doorbell “v1”.
